- Joined
- Mar 8, 2009
- Messages
- 44,098
Re: Changed Plug wires and distro cap - now boat will not start
Sounding like there is a loose connection somewhere. Moving plug wires around should do noting except make it run bad if they become out of order. So I take it the engine is now running but may need to set idle?
DSWI, I haven't set idle speed and actually didn't know I needed to. I will look in the stickies to see if there is a procedure there. Any guidance would be appreciated.
We did check for spark when at the pier the day the problem occurred and my buddy said that he saw nothing. I did not recheck when I got the boat back home. I just reversed the plug wires from plug to distribution cap and tried to restart. At that point engine ran fine again. Is there anything obvious that I am missing that would allow an engine to run on the. Jeff's just fine but not allow the engine to start sitting pierside?
