Changing prop for 1st time
21270
This will be the first time changing the prop on my 1993 gen 2 drive, besides the new prop is there anything else I need to replace (splined washer, tab washer etc...)?<br /> Thank You!
Re: Changing prop for 1st time
You'll Need the hardware that matches the New Prop.......They're Not all the Same.......<br /><br />And,... You'll Need to Grease the Propshaft......
21270
Thanks Bondo, I will contact Mich Props and get the parts.
