Charging system on V6
My problem is that the battery doesn't seem to be charging. Battery reads about 12.02 to 12.16 volts not running. With the motor running it read anywhere from 11.9 to 12.04.
I was told that this a "high rpm" charging system so it need s to at higher rpms before it kicks in. Is that correct?
thanks for any help.
Re: Charging system on V6
This seems more like an engine question/issue instead of a Glastron issue.
Maybe tell us some more about the engine, etc.
"High RPM charging system" . . . that's a good one, I'll have to remember that.
