Checking Alpha 1 Drive
Roman S
Beside pressure testing, is it possible, once the drive is split apart to check operation and make sure nothing is grinding or damaged. I was thinking of putting a socket either on the prop splines or the shaft and see if I could turn it with a strong electric drill.
Thanks Roman
Re: Checking Alpha 1 Drive
Ayuh,... Turn it by Hand.... Turn it by Hand to feel it's smoothness....
