Checking oil in DP-c1
Burns363R
How do i properly check the oil in my DP-C1. Took it to a boat shop and they filled it. Ran it one weekend and figured id check it out. Its not on the dip stick at all. But if you read the manual they say to fill it to the fill plug.
So should i add more oil untill its on the dip stick?
You check the oil via the dipstick.
Yes, add oil
