Chevy 5.7 I/O - Fresh Water Cooling Question - Need Help ASAP, really wanna go fishin
cc190cc
Greetings,
I purchased this boat last year with a blown engine, the PO overheated it and wiped it out. I replaced the engine over the winter and got it running well. I then forgot to drain water from manifolds and exchanger and cracked them, no damage was done to the engine.
I ordered replacement manfiolds and bought another heat exchanger from a local. After some research i have found that the mercruiser exchagner i bought has an extra port on it for a heater, dont know which port is actually for the heater but figure ill just block it off.
The old heat exchanger was installed incorrectly, it was a san juan setup with the radiator cap on the thermostat kneck. The exchanger itself was located above the radiator cap, if i opened the cap, all coolant would come out. I have my suspicions that this was causing an air bubble in system and likely why old engine failed after 5 years. When i filled the system up after motor replacement, i had to remove one coolant hose from the exchanger to add coolant.
I considered ordering an identical replacemetn exchanger and mounting below the engine where it belongs, though there is not enough room for it.
The replacemetn I purchased is a mercruiser unit with the radiator cap built in, I know the cap needs to be the highest point in the system. The exchanger has a total of five ports on it.
Will I have any problem using this system exchanger with me Volvo penta exhaust manifolds. There are a lot of hoses and im starting to get confused, and im starting to get anxious because i should be fishing. If i had a few extra $$ i would pay someone to finish it. Im very mechanically inclined, just need a little guidance on the plumbing.
Does anyone have a diagram or something, my old manifolds only had 1 hose going to each, some picutres i have found online have multiple lines going to the manifolds.
I can post pics if it would help, really hoping for sea trial this weekend. It ran great when I started it prior to the manifold and exchanger freeze up.
I can post tons of pics if it would help, just tell me what you need to see.
Chad
Bt Doctur
Re: Chevy 5.7 I/O - Fresh Water Cooling Question - Need Help ASAP, really wanna go fi
Pics would be helpful ,but generally speaking raw water "in" from outdrive pump or remote pump goes thru the exchanger to the "out" port.From there it is split to feed both maifolds , then out the risers.
The A/F side goes to the lower hose on the engine circ pump ,the other port goes to the therm housing
cc190cc
Im going to post pics of my exchanger in a few, thanks a lot for the response.
Chad
cc190cc
Don,
Thanks for your help so far, i trully appreciate it. Here are some photographs. I have purchased brand new manifolds but these are pics of the water port on the old ones. I also understand that I will have to put a different water kneck on to use this exchanger, will any 350 water kneck work? Please provide any feedback you may have. I wish i just had an extra 800 for new kit for motor but its just not in cards right now. Please just tell me the best way to get this thing fishing.
Chad
cc190cc
cc190cc
Bt Doctur
Looks like you will need a merc therm housing also . That manifold is used on the Blue Water inboard engine also.It`s rear mounted though. This pic is how it goes .
cc190cc
Thanks a lot, the guy i bought the exchanger from said the two on top went to the exhaust manifolds, he didnt seem 100% sure though. Do you have a part number or link for the right thermostat housing that I need?
