Choke Voltage
Sunken Ship
'99 4.3GL PWTR
Anyone know the correct voltage for choke terminals. Getting 7.0v. Correct? Expected 12v there so I wanted to see what you guys thought.
you have a bad connection somewhere if you are only getting 7 volts.
Maclin
Are you measuring from the Positive terminal to battery ground? Or across the terminals?
Purple wire is ignition
Black wire is ground
On a vp, the grounds terminate on the block, back of block, on one of the flywheel housing bolts, near where the ground cable from battery is.
Purple wire runs thru a few connections from the helm to the + side of coil. This is also where the choke is connected
If your ignition was changed and you now have a balast resistor or a resistor wire, someone could have put the balast in the circuit incorrectly
Sunken Ship
Thanks, it would have taken me a while to figure that one out. Ground for choke is to the carburetor base nut-maybe someone changed. Did find a somewhat representative schematic indicating "AC" terminal on the alternator as point of termination. Will do some probing....next spring; winterized yesterday. Already counting the months. :lol:
ground to carb base is common... if you see any corrosion, clean it.
