chrysler 318 - no spark
diamonddave
Ive got a 1976 Pacemaker 30 S.F. with twin 318 chryslers with electronic ignition. Tryed to start engines today, port fine, Staboard would not start, fiddled around a bit, found I had no spark, except when I released starter I did notice a spark. Swapped coils, same thing, heading back to boat tomorrow, any ideas would be greatly appreciated
Re: chrysler 318 - no spark
Solenoid ???<br />Key-switch ???<br />Bad wiring in-between ???<br />Sounds like the coil is losing power while motor is cranking....
akriverrat
if you have one? ballast resistor. classic problem.
akriverrat
stupid me. not ballast resistor. that is spark when cranking.none on release.
diamonddave
Had the control box cover off on Sunday, checked voltages at various sensors and compared them to port engine. Found some inconsistensies, I figured loose wires. Tightened any connections I found and she started. Hopefully a fluke 1 time occurance. Kinda nice having twins to check readings etc. Thanks for the help,I love this forum
