Chrysler 707HE 70 HP Outboard
Isa4325
Ok, been looking for a distributor cap and carbon center tip With no luck. My question is I have a perfectly good distributor cap but the sinner sprung carbon tip that goes to the road or when the Cabazon broke and no longer exist. Is it possible to use a carbon brush for an electric motor and shape it to the right size and put it in the same hole with the spring and the new carbon tip and make it work. Or does anyone else have a solution with no luck. My question is I have a perfectly good distributor cap but the sinner strong carbon chair that goes to the rotor when the cap is on broke and no longer exist. Is it possible to use a carbon brush for an electric motor and shape it to the right size and put it in the same hole with the spring and the new carbon tip and make it work. Or does anyone else have a solution. ?
jerryjerry05
Try it??
Maybe try Franz Marine.
1972 70hp.
Post a pic of the cap and the other parts.
I have trouble finding a parts diagram on anything older than a 75
ebay has parts for your dist.
Isa4325
Sorry Jerry no pics, but I will get some this morning and post them for you.
Isa4325
This is the cap with all points transferring current including the center spring where the current brush is missing. Disintegrated?
Nordin
Have you tried Franz Marine?
If he does not have it then Ebay is the source.
