Clarify OMC 5.0
wrosales
I have heard from numerous people that this engine is the same as a Ford 302. Does that mean I can by parts for this motor from the autoparts store? Thanks,
William
zbnutcase
Re: Clarify OMC 5.0
Could be a 302 Ford OR a 305 Chevy, and no on the autoparts store for anything external, except sparkplugs and belts
wrosales
Re: Clarify OMC 5.0
How can I tell? I was going to buy the spark plugs and spark plug wires. Thanks
a70eliminator
Re: Clarify OMC 5.0
OMC did use Ford 302's and the basic engine is the same as a car or truck with respect to block crankshaft rods pistons heads, although all the bolt ons like alternator starter flywheel distributor are all marine application only.
Re: Clarify OMC 5.0
Ayuh,... Sparkplugs are fine, the wires are probably Different...
Bt Doctur
Re: Clarify OMC 5.0
Ford dist are in thef ront, gm dist are in the rear
