Classic 50 ?
Papafluff
I have a 1986 classic 50 that needs the upper mounts replaced. When I pulled the power head to gain access to them I noticed I could not turn the drive shaft. The lower unit is still on. No matter what gear it's in even neutral I can't turn the drive shaft by hand. I can turn the prop shaft in neutral and when it's in forward I can turn it and hear the clicking but can't turn it and get the drive shaft to rotate. I lowered the power head back down and could turn the flywheel and prop shaft rotates normal. Before pulling the power head all was fine motor was running and gears shifted normal. Why can't that driveshaft be turned with powerhead removed yet seems to turn fine with power head on? Is this normal? Any info would be greatly appreciated
It takes a fair bit of effort to turn the waterpump.----Use a pair of pliers on the shaft and likely it will turn easy.
Papafluff
Racerone thank you. I did as you said and was able to turn drive shaft. I could actually hear water pump impeller squeaking so it was exactly as you said. Thank you so much for the input. I was concerned that I might have a problem. Best wishes hope you have a great summer
