cleaning and painting Bravo drive
jere1972
any ideas on what kind of paint to use on the drive and gimble, never had much luck with spray can stuff, I used dupli-color paint shop laquer in the quart can on my outboard, looked beautiful for about 6 months, guess something went wrong with the clear coat and became blotchy, I've seen some YouTube videos of people shooting Rust-o-leum high performance and adding a hardner, and thoughts? I would like to try and achieve that original mercruiser fiinish and durability
Re: cleaning and painting Bravo drive
Some folks treat their outdrives like a work of art and get high end paint, etc., following Mercruiser recommendations to the letter.
Others get a can of Krylon black and have at it.
I am going to be re-finishing the outdrives on my soon-to-be new (to me) boat . . . I will probably use Interlux Primocon primer as the base and top coat with black engine enamel or something like that.
Many folks use the rustoleum paints for outdrives. I think if you use a quality enamel, then you would be OK.
Us salt water guys have to paint the outdrive with anti-fouling anyway, so it ends up looking dull and boring, regardless of how nice it looks prior.
Ayuh,.... Congrats Ted,... I guess the search is over,..??
Ayuh,... I shoot my drive every year or 2 with rattlecan Rustoleum...
Yer never goin' to get a paint job like the original,..... ain't gonna happen....
Oshkosh1
Ensign
I simply cleaned mine, roughed it up with a green scrubbie, soaked it with a good dose alcohol based brake parts cleaner, let it dry then (following the advice here), simply used "rattlecan" paint. I had some "Phantom Black"...but will use the Rustoleum next year. Still looks good!
mohead1
Factory says to sand/scuff all bare aluminum spots and painted areas, treat bare alum with "alumiprep 33" to remove oxidation, primer with a zinc chromate type (several on market), then finish w acrylic enamel........
OR....just get sum rustoleum and spray er down.....lmao....
TilliamWe
Banned
Anything more than scuffing the corroded spots and spraying with a rattlecan (Rustoleum is the best) is a waste of time, effort, and money.
My other advice to you is "LEAVE AS MUCH OF THE FACTORY PAINT AS YOU POSSIBLY CAN!" As Bond-o says, it's never going to be as good as the original, so don't sand off anything that is still good.
45Auto
I've repainted many drives using the Mercruiser factory recommendations. Oldest one I've done was my B3 when I broke the gimble ring in 2005 and it still looks brand new. Minimum quantities on the materials will cost you around $250, but you'll have enough to do about 4 drives. If you're only doing one it's going to be expensive.
The Mercruiser procedure and materials is about half-way down this FAQ page:
http://www.mercuryracing.com/techcorners/mercruiserfaqs.php#tech_11
jere1972
any Idea on a online supplier for the ditzler products
