Cobra 2.3L oil change question, first timer!
YeahBuoy
Hello everyone,
I recently purchased a 1989 Bayliner 1750 capri with an OMC cobra I/O 2.3L.
I'm going to change the oil but I am unsure of the type of oil to use.
The factory manual calls for SAE 30 and does not recommend multi viscosity oils such as 10w-40.
However, a trip to my local boat mechanic has taught me that omc is out of business and that I should use Volvo-penta brand oils and filters as a replacement. What I am unsure about is that he sold me 6 quarts of synthetic 10w-40 Volvo-penta brand oil and a filter of the same name. I brought him the manual which called for sae 30 but he insisted that the 10w-40 is what I need.
He says that Volvo-penta used to recommend the same but they changed the factory recommendation to 10w-40? Is this true? I mean the viscosity isn't even right. Should I just buy SAE 30 online? He didn't have any which leads me to believe he wanted to keep the sale.
Can anyone help please and thank you in advance
Re: Cobra 2.3L oil change question, first timer!
The Volvo Penta oil will be fine since it is a synthetic oil or just go to the auto parts store and buy straight 30W.
You don't want to use regular 10W-40 non synthetic oils.
YeahBuoy
Thank you for the response!
I actually managed to get a hold of the guy who sold to to me and he's been using synthetic 10w-40 so it looks like I'm in luck :)
Again thanks for the help!
jerryjerry05
The synthetic or regular oils either is good.
Depending on the conditions? for the multi viscosity?
Where do you live?How you gonna run the boat?
Year round use?Florida,I'd use 10-40 north 10-30.
You'll get as many opinions as there are oils.
Your best bet is contact Mobil oil.
They have an question/answer section.
The most important thing is keeping it fresh.
Using the right stuff in the drive and filling it right.
Filling it wrong will cost you a drive.
YeahBuoy
I live in Los Angeles and will be mainly using it at castaic and pyramid lakes. No salt water.
The previous owner also lives in SoCal and also has only taken it to castaic and pyramid.
I'm not gonna be racing or anything just cruising and water skiing really.
Yes it'll be year-round use, and I may take it up to lake arrowhead in the summertime.
Can you shed some light on the right oil for the drive and how to fill it correctly? Again I am new to all this and would only want the best for my new baby.
Thanks :) it's much much appreciated
Lou C
alignment tool.jpgFor motor oil, you can still find straight 30 oil and if you have a West Marine or similar store you can find:
Pennzoil Marine straight 30 or 15w/40, Chevron Delo 400 in the same weights, same with Shell Rotella. Interestingly the Delo and Rotella used to be rated for both gas and diesel in the straight weights, now they are rated only for diesel, but the 15/40 is rated for both.
You can also use the Merc 25w/40 oils that are specifically designed for sterndrive engines. Just do not use an automotive type multi vis oil, because they can thin out with sustained high rpm use.
Personally I'd use an oil specifically formulated for marine use, like the Pennzoil Marine or the Merc stuff. Keep in mine that this stuff didn 't exist when you owners manual was printed.
I have used the Merc High Performance gear lube in my Cobra for over 10 years and its just fine, easy to find also.
filling the drive as to be done the OMC way, do a search it has been posted many times.
You remove the top dipstick and set it in the hole, do not screw in.
YOu remove the bottom most drain screw. Let it drain fully. After its done, replace the drain plug with a new gasket. Then remove the fill plug, which is on the foward edge of the drive, near the joint between the lower and upper gear units. You hook up your gear lube pump there. Then you pump in 2 full quarts and then check the dipstick. It should read close to full. Now screw in the dip stick and quickly remove the gear oil pump from the fill hole. Re-install the fill plug with a new gasket. Let it sit for a while and re-check from the top dipstick, you may have to add a bit to get it to be full, because you can get air bubbles filling it. Most Cobras take 2 full qts. cobra drain 1.jpg
NOTE: this pic does not show it, but the dipstick is the large screw in the center of the top cover. YOu can see it in my top pic, ignore the alignment tool LOL
+++1 The 10W-40 in particular is a bad automotive oil to use as its Viscosity Increasing Product breaks down.
Lou C
And honestly there is no particular reason to use Volvo Penta stuff on your OMC Cobra. I have used Sierra oil and fuel filters for years, with no problems, and I use the Merc 25w/40 motor oil and the Merc Hi Performance gear lube. Yours is an older engine, I don't know that I'd use a full syn engine oil in it anyway. I used to use the Delo 400 single weight in mine but it is no longer rated for gas engines so I switched to the Merc stuff. Merc's is rated for both gas and diesel. It costs a bit more though.
I do use the OE stuff for impellers, and bellows esp the driveshaft bellows.
You can also use Merc's Quicksilver filters for oil and fuel.
The engine you have, is a vintage SOHC Ford, that was used in millions of Pintos, Bobcats, Mustang IIs, Ford Ranger pick ups, etc. It is a belt driven SOHC and that timing belt can break, and leave you stranded. Its a good idea to check it and if the belt is looking worn, to replace it. You can't see it without removing the belt cover. Years ago my brother's girl friend had a Pinto wagon with the same engine and the belt broke and left them stranded. I picked them up in my much older Ford Torino (Fairlane) with even more ancient 302 V8....
icyveins
not trying to hi-jack the thread, I have a 2.3l also. if I put straight 10-30 valvoline in I should really take it back out and put something else in?
10-30 is not nearly as bad as 10-40. What I noticed with mine is that as I put more and more hours after an oil change, the oil pressure at idle(warmed up engine) would be progressively lower.
After I switched to Mobil 1 15w-50 synthetic, my oil pressure doesn't dip at all at idle.
Lou C
I've had the same good results with the straight 30 and 40 and the Merc 25w/40, my hot slow idle oil pressure is always pretty good (like at least 20 psi). And this is a 25 year old original engine....
If you look at all the different oil viscosities recommended by Merc, Volvo and OMC it gets pretty confusing....since they changed their recommendations over time....but the viscosities typically recommend for auto use (5w30, 10w30 etc) were usually NOT recommended...
I feel that at least the Merc stuff is tested and recommended for this application and will keep their warrantee in effect...and....Crusader and Indmar both have recommended 15w40...so those are probably good general guidelines....If I had a Merc engine in warrentee I'd use their stuff at least during the waranntee but I'd love to see some reliable test results comparing Merc, to Pennzoil/Delo/Rotella 15w40 since those are the ones I'd consider most....
HT32BSX115
Yeah. Back in the early 90's I think, Consumer reports did a test of oils and drain intervals on a fleet of taxicabs on the east coast.
They concluded that (regular non-syn) 10W-40 shouldn't be used in ANYTHING because it wouldn't stay in grade due to the excessive amounts of VI improvers used.
This is true for NON synthetic oils in general. The larger the spread between the low temp and high temp viscosity, the more VI improver that must be used to achieve that large spread.
Synthetic oils do not use VI improvers. They're designed to pour down to extremely low temps but maintain rated viscosity at 100C.
Multi grade (syn) oils are really necessary for (really) low temp operation. But in a boat, much of the advantage is lost using (synthetic) oils like 0W-30, 0W-40, 5W-30, 5W-40 and even 10W-30 or 10W40 because the low temp properties are not needed.
If you DID need those low temp props, the lake would be FROZEN and you wouldn't be going anywhere anyway!
You could get away with using straight-wt SAE30 year-round............. and since you're trailering your boat, you also probably don't need to use an NMMA FC-W type oil....
YeahBuoy
Ok so in conclusion my Volvo penta 10w40 full synthetic is perfect??
Arghh this is quite frustrating haha
YeahBuoy
Awesome, much appreciated!
You'll be hearing a lot more from me in the future on this forum :p
HT32BSX115
Well, yes. (to both Q's)
BUT, Many people have a basic misunderstanding of the SAE's oil designation system.
For many years, automotive motor oils were (and for the most part still are) designated by a viscosity rating. Kinematic Viscosity IS a measurement of resistance to flow at a specific temperature. HTHS is the upper rating for an oil respecting shear at high temps.
SAE Viscosity Classes of Motor Oils according to SAE J300
Ideally, you want an oil to flow at extremely low temps (well below freezing if you operate in those temps) and still have decent lubricating qualities at high temps (the engine, coolant AND oil fully AT operating temp!!)
The oils of yesteryear, COULD NOT do BOTH! .................... SAE 30 & SAE 40 are literally GELLED at -35C for example.
It might be a semi liquid in the oil pump gears and actually produce a high pressure reading at your oil pressure gage, making you think everything is ok during start up....... BUT your rod, main, cam bearings AND your valve train are RUNNING with NO OIL because it cannot flow to those areas at that temp until it warms!!
So auto manufacturers recommended using an SAE 30 or 40 oil for summer use and an SAE 10 or 20 for winter use.
Some, who used 30 or 40 in the summer and did NOT change the oil for winter, saw catastrophic engine failures when it got cold enough to thicken the oil where it didn't flow.
If they ran 10w (winter) oil into the summer, they saw VERY low oil pressures in a hot engine in the summer and severely increased wear. (which wasn't very obvious)
In the 1950's, The industry developed VI-improvers that, when added to low viscosity oils, caused thickening as the oil reaches higher temps.......creating "Multi-grade" oils.
So in the case of "dino" (NON-syn) oils, if you use SAE10W-40, You ARE USING A 10W oil! .......... If you're using 15W-40 oil, you're using a 15W oil.
Those oils have Viscosity-Improvers added to thicken (or "stay" thick) at higher temps.
Those VI-improvers eventually break down. As they break down, the oil becomes thinner and thinner at those higher temps. (That's one reason to change it......in addition to getting "dirty") You change the oil long before this is allowed to happen (presumably)
Synthetic oils are QUITE different. A straight wt synthetic oil does NOT thicken at lower temps like a straight weight mineral oil.
Synthetics DO NOT use VI-improvers like straight wt oils so there's little or no degradation (like mineral oils) so they are able to perform (stay in grade) longer! They DO however still get "dirty" with combustion products,condensed crankcase water etc and "dirt" that gets into the intake system through the air cleaner and past the piston rings.
The oil filters can trap some of it but not ALL of it! (.....why you STILL need to change the oil!!)
You can read more if you like by going to the following links.
How Do You Choose the Right Type of Oil for Your Car?
If you REALLY want to get technical: http://www.infineum.com/Documents/API/API Engine Oil Classifications 2010.pdf
There's more to read, just do a search. It's all over the internet.
I would suggest staying away from actual manufacturer sites like Chevron, Mobil, Am$oil, etc because their sites are mostly aimed at selling you their products......
Going to sites like API, SAE, (since they don't sell anything directly to the public) can give you more objective info...............Lubrizol, etc. Although Lubrizol doesn't sell anything to the public they sell to Industry.....and they DO make most of the additives that go in many branded motor oils and motor fuels.
All the above "stuff" is argued DAILY, on every "motor" (auto, truck, boat, lawnmower, leaf blower, motorcycle, airplane etc) forum-site all over the internet.
A LOT of people use a particular (brand) oil and oil/fuel additive for emotional reasons.........
Examples: Marvel Mystery oil (and other "Snake" oils) = My uncle, Dad, Brother, Pet Mechanic, Mercedes mechanic, Ford Mechanic, Mercruiser Mechanic......etc etc etc TOLD me I SHOULD use it!!! (really!!!! ............. they said you need to put mineral oil, Stoddard Solvent and LARD in your oil (or gas for that matter!!!)????:laugh:
Royal Purple = pleasing color, Chevron = well known name, Volvo Penta (Mercury, Yamaha, Evinrude, OMC, etc etc etc)= made my boat engine ............ Come on people, Do you REALLY think the those companies "MADE" those lubrication products?:facepalm:
Oh gawd!!! Here I go again! Another soap box rant! Somebody stop me!!!! (Bondo is laughing at me again!!!:D)
Sorry guys!
Whew!
That "dealer" is in the business to make money. They make money on that oil. That 10W-40 oil IS a synthetic and is fine. You're also just "fine going to Walmart, Oreillys, Autozone, etc and just buying Mobil 1 or any other synthetic. OR you can just use any brand SAE 30
For the Original Poster.
Just use what the manufacturer recommended back then or what they recommend NOW. you won't go wrong in either case.
ymmv......
Rick
YeahBuoy
Awesome reply! I don't think I'll be looking any further for oil info
Thanks!
palace
Thanks!
Go to wally world get single SAE 30w synthetic and she will take care or of you. Have been running in my 1987 3.0 OMC cobra. I have also been using WIX oil filters as well.
Seen pictures of arrowhead lake it looks beautiful.
I have never seen straight 30W synthetic at Walmart. Care to share a link or a picture of the bottle?
