coil on a 1974 mercury 650 with thunderbolt ignition!!!!
hfd12
i was wondering/ im not getting any spark so i looked at the coil on the side of the motor and its all cracked in different directions ? is it bad? thanks and is cold compression of 125,135,135 psi good as well? thanks :)
Re: coil on a 1974 mercury 650 with thunderbolt ignition!!!!
Cracking is usually death to a coil. Replacements are avail from CDI, Sierra etc. You have the big ugly red coil, right? The replacement will be a smaller black plastic coil with a metal cover.
hfd12
I have one ordered and should be here in a week. no its not a big red one its the black one with the metal cover, sop i should asume its been replaced already atleast once. what causes it to crack? thanks for ur info its greatly apprecitated
I am not certain what coil was on that motor. You can look at the picture on crowleymarine website, and likely tell, if you are interested.
I think the older coil was attached differently, then the replacement coil. The newer coils had three 5/16" bolts, arranged in triangle. How was your bolted on?
emckelvy
The 3-cyl motors came with the smaller coil. Cracked is bad!!!
danimal69
in 1974 the 650 3 cylinder came with a black coil
