Compass placement
jpullin
Will placing my compass on the console, between my VHF and my fishfinder, cause adverse compass readings?
fishmen111
Re: Compass placement
Shouldn't. Magnetic interference is usually the culprit. Speakers, generators and such.
External Combustion
It depends on the current draw of both of the electronics. The current will produce a magnetic effect, but it may not be enough to bother with. Swing your boat through a compass rose with and without the items on and find out.
If it does you might be able to reroute your power cables to cancel the effect.
The short answer is yes.
The installation manuals my equipment state the following minimum safe distances:
Icom 502 VHF - 39"
Garmin 4208 GPS -30"
Furuno 582L FF - 30"
All my equipment is mounted in the ?safe? zone except the GPS (roughly 15?)which affects the compass if the GPS is on.
I don?t worry about it because I generally navigate using GPS and I can always turn off the GPS if I need the compass for some reason.
