Compression test on Ford 5.0 FL motor
akfishin
All,
Previous owner replaced long block. I figured as I was changing the manifolds I might as well do a compression test while it's all torn apart.
My lowest was 115-118 psi, highest was 125 psi. Test was done cold (40 degrees outside).
Are these numbers acceptable? How much do they increase when the engine is hot.
Thanks!
Dan
Re: Compression test on Ford 5.0 FL motor
Ayuh,... Barely passable...
Run it, 'n test it again...
jerryjerry05
Low numbers could be a cheap tester or not done right.Remove all the plugs.Then start again.
There could be as much as 30# difference between testers.
The thing to look for is all the cylinders about the same.Any more that 10% difference look into it.J
