Compression test
Freeman1982
Hello friends, I replaced the head gasket to my engine it’s Volvo penta GXI 5.0 because I have 115 psi in one cylinder and the others have between 130-135 psi
After I changed the head gasket and changed seals valve re machine the head , now I have my compression test in all cylinders 137 except one of them 125 . Is that mean the lower engine weak like having bad oil rings or bad cylinder ?
Note : after replaced the head gasket I did not took the boat to the lake yet I just run it for 5 minutes in the garage . So do you think the compression will go up after run the boat in the lake ?
I checked online it’s says compression test for healthy Volvo penta GXI 5.0 engine should between 120-175 psi . I need your opinion ?
I did all this work because the boat facing hard time to getting on the plane .
Thank you
stouchton
Basically, compression readings should be within 10% of each other on a "healthy" engine. Some folks say within 10 psi. So, you are right there on percentage and just outside the 10psi rule - which is a rule that does not make much sense since it does not take into account actual compression ratio. To further learn why, you would need to do a leakdown test. There can be some very minor reasons contributing to this (air flow, carbon, slightly leaky valve seat, etc). In my book, close enough to run without second thoughts.
Horigan
A simple test is to squirt oil in the cylinders and repeat the compression test. If the pressure is higher, you have bad piston rings.
ESGWheel
Ensign
As the others indicated, you should be good to go and if you desire to investigate more, that can be done. However, I am concerned about your symptoms to get up on plane. A V-8 5.0 with low compression (but not that low) on only one cylinder I would not expect to significantly degrade the performance of the boat.
My suggestion: get the boat on the water and see if any change. Post your findings and if no change also include as much info on the boat / engine history, etc. Thanks.
Donald0039
It's not clear if you had the heads machined (valve job?) or just new valve stem seals.
Did the boat ever get on a plane quickly or boat new to you?
Not getting on a plain can be many things from old gas to growth on bottom of the boat, to wrong prop.
Freeman1982
Will do thank you
Freeman1982
I re machined both heads and changed the seals
Freeman1982
I did not check it on the water yet . But my concern is the psi reading. 137 is not close to 175 there is 35 psi difference. So that what makes me think I may have bad oil rings ???
Freeman1982
Thank you guys and appreciate your comment.
As I check it should be between 120 -175 psi i know I am in the range but close to 120 psi
I re machined both heads change the seals re do the valve changed the gasket and I am not satisfied with the psi reading
I will check it on the lake and get back to you with the results
Thank you
Donald0039
The oil control rings scrape oil and prevent excessive oil burning. Above the oil control ring are the two compression rings. They are what control compression along with the cylinder walls.
Dump a little oil into each cylinder and rerun the compression test. If it gets better your rings are worn. If it does not get better you have a valve problem.
Check your gauge
New motor would be 150 psi on cranking compression
If adding oil brings the numbers up, you have ring issues requiring a rebuild
A cylinder leak test may be more revealing than the compression numbers.
In general, your engine is OK, but not great.
Did you do the compression test with throttle wide open? I like to do the compression tests with the outdrive off (can't always do this) and battery being charged throughout the test.
Freeman1982
Check your gauge
Thank you for your response, the story is I have a mobile service mechanic change the head gasket for me and he couldn’t get the engine running. So I let him go I did my research and I get the top dead center right and get it going. Then when I did the compression test I saw the psi 125-137 between all the cylinders , so I had a doubt he did the lashing valve wrong , so I reopened the head cover and re did my research and got the compression test between 150-170 psi between all the cylinders, I was doing lashing valves and compression test same time . I believe I got it right I went through the firing order 1-8- etc… with TDC each cylinder with 90 degree engine turn . So now should be good . But i noticed something and i believe it’s been going on for awhile, i have one exhaust 11 degrees higher than the other see pictures below also i have the RPM 650 which this been going on for awhile. Please see pictures below and give me your opinion
Freeman1982
Freeman1982
Freeman1982
Freeman1982
Check your gauge
