Compression
Sebago13
Would anyone know what the compression should be for a 1971 20hp Johnson. 20R71S
There are many , many of these motors around that have hardly been used over the years.------Some spend much time in proper storage.----Used for just a few hrs every year.----If you just bought it remove the flywheel to check the coils.-----Bonus if you finfd them cracked.
Bosunsmate
Not sure why you would want them cracked, didnt think they were like walnuts but am here to learn too
lindy46
Cracked means original and it probably hasn't been used for years and is most likely a low hours motor.
Exactly----If coils are cracked then it likely has not been used for many years.-----Most likely then a low hrs motor.-----I see that all the time !!-----I have many new coils on hand here as it is a very , very common thing.
jerryjerry05
The comp readings: as long as they are even or real close.
Different gauges read differently.
Harbor Freight sells JUNK and they don't give the right readings.
Bosunsmate
Ahh interesting, "cracked" in that sense seems to be an exclusive North Americanism
I see a lot of German, Japanese, and especially British Engineering that is Cracked
