Compression
rodsnguns
Will a mid 70s 70hp Johnson still run decent with the compression on all 3 cylinders averaging 70 to 80 psi ?
rodsnguns
Ok, went and got a higher end compression tester to see if my obviously cheep one was junk. The original readings were all 3 between 70-80. The better guage shows top-115, mid-110, and bottom 120. I assume these numbers are acceptable for a 1977 year motor ?
not so bad for a 50 year old engine...
if it works don't fix it.
maybe try some engine cleaner/decarb product to clean out some carbon deposits. Some like Seafoam some don't.. no harm in trying see utubes.
Evinrude engine cleaner or Merc power tune should flush out some nasty stuff.
Motors that have sat unused for long periods of time sometimes has the rings stick and causes low compression readings. Thus the reason for using the power tune and other additives. Once the motor is running, try another comp test....results could be different !
rodsnguns
Kinda what I am thinkin too. Once I get er runnin I will do the decarb process then dump a can of sea foam in the tank . Mite just bring the Ole motor back to it's youthful days.
I am one of those who has NO use for SeaFoam
You could get some Power Tune/Engine Cleaner/ CRC's GDI Intake Valve & Turbo Cleaner, remove the Spark Plugs. With the engine tilted up, spray some into each cylinder, let it sit a while, rotate the engine a 1/2 rev and repeat.
I am one that has had great success with SeaFoam....to each, his own, I guess.....
seafoam sure cleared up my honda snowblower hick-ups (surging) !
I was going to swap in a new carb ( from amazon) but never had to after I ran seafoam . Been good now 2-3 years :)
I use inexpensive tranny fluid or whatever else is laying around.
Rarely do those come back. Compression testers are all over the board. I only trust the one I got in 1979.
rodsnguns
Hey salt, what are you referring to when you say "rarely do those come back". Are you talking about the compression on an old motor after a decarb ?
Yes....it can but.....
Running it more and testing it warm will help bring the numbers up but your numbers are acceptable to me.
Learn how to resurface the head if you haven't already and send pics of this motor (whole and under the cowling) to see if you need other info to keep this wonderful outboard going.
Good job so far!
