Contacting mods
Is there a way to contact the mods as a group rather than individually? 0
Use report function and we all see it, but not like a pm
OK, the report function is my question is will try to gather up all the mods in one message. Can you add to the conversation if I should miss some?
Fun Times
In the post report section the mods would be the only ones to be able to see/read it and in a different way, talk about the situation at hand though the system works slightly different than the normal forum functions do ‘such as if one doesn’t keep go looking at the reports, you don’t really know when there are multiple updated posts where in the private messages area, you’d see the numbers in the mail box highlighted in red.
If you start a private conversation with say one or two members, for example, you would still be able to invite others as you go along if desired.
Out of the following list there are two members that don’t participate any longer which is colonel_sanders and Scott Copper.
