Contessa command bridge trim tabs
Hi all
which tabs would be better. 30x9. Or 24x12. Bennet say
“In general the widest span tabs that will fit on the transom will be the most effective. The greater the surface area, the greater the lift. We‘ll typically recommend a 9” chord tab (length), but depending on available transom space a shorter or longer chord tab, or specially shaped tabs with upfins or dropfins may be advised.”
unless im wrong and its likely the 24x12 have the greater surface area.
andrew
welcome to the forum. Based on your other post i believe you have greater challenges ahead of you.
