Control Shifter Stuck
seabass
My control shifter is stuck in the neutral postion and will not move in reverse or forward. Any suggestions on what is wrong an how to fix it?
USS Neversail
Re: Control Shifter Stuck
What year and model and manufacturer and horsepower? That'll help the smart guys (not me, in other words) help you.<br /> :) <br />Jason<br /> :cool:
disconnect the cables from the engine end..... is the control stick still stuck ??? then disconnect the control ends.... does the stick move now ?? probably the cables are frozen.... replace the cables......OR possibly there's a "trigger" to squeeze to shift into gear....<br /><br />Bondo
