converting points to HEI??????
concordsteve
I have a 1981 concord with the 305 merc with the points setup. Can this be converted to a HEI system with a kit. I converted my 69 camaro to HEI with a very simple kit that bolts into the stock distributor and am very happy with the performance and reliability of the HEI setup. Can you do the same with boats?
dr_bowtie
Re: converting points to HEI??????
yep it's called Pertronix....get the marine one located via the link at the top of the forums
Ayuh,... I'd buy a used later model T-Bolt IV myself,...
But Ya,... Pertronics probably sells a Conversion for it....
