- Joined
- Dec 29, 2002
- Messages
- 3,984
Thanks Art, going to give it a go.@FLATHEAD ... per your request in the hunting thread ... (the one I have in the fridge has been swimming in the brine for 7 1/2 days now ... I will be there for another week. It is a deboned hind quarter that weights about 14 lb)
Venison Ham
Ingredients
Preparation
- 2-3lb venison hind quarter roast with most of the fat trimmed away (adjust recipe according to weight and don't be afraid to add or delete flavors to the mix)
- 1 gallon water
- 1.5 cup kosher salt
- 1 cup brown sugar or Real Maple Syrup (not the corn syrup based junk) or Molasses (I generally do 1/2 brown sugar and 1/2 maple syrup)
- 2.5 tbsp pink curing salt (1 oz per lb of meat)
- 2 tbsp whole black peppercorns
- 2 tbsp mustard seeds (or a pinch of ground mustard)
- 2 tbsp coriander seeds
- 3 bay leaves
- Can add cloves of garlic if desired
- Mix all ingredients except venison in a food safe container, stir, and bring to boil. Allow to cool completely before adding venison and make sure it is submerged completely, adding weight to the top of the venison if necessary. (I like to do it in a 5 gallon bucket lined with a clean garbage bag. Tie the garbage bag tightly so the entire piece of venison is submerged.
- Let brine for 7 days, or longer if you have time. The longer the better, a week for smaller hams and longer for larger hams (a 7-10 lb ham would be 8-10 days, etc). You can use a marinade injector to get the brine inside the meat if you don’t have the time to let it brine naturally, cutting down your marinade time slightly.
- After brine, remove and place in Smoker with apple wood (maybe a little hickory or mesquite added to the mix) at 180 degrees for an hour or 2. Then raise the temp to 225F until internal temp reaches 150F.
- Let rest for 20 minutes and enjoy! Or, chill in a fridge and slice thinly for sandwiches!
