- Joined
- Mar 18, 2009
- Messages
- 15,097
*** out there, buttered or not.There are weirdos buttered, never can be too careful....
Not really. I mix 4 pounds ground venison with one pound of ground beef. This time I used a spice mix from Owen’s BBQ has a cure right in it. I normally do my own mix so I can keep the cure to a minimum. 5 hours in the dehydrator does the trick.Never use ground. Is there a binder?
Any idea what the finished weight was? Just curious don’t go out of way to answer that.Not really. I mix 4 pounds ground venison with one pound of ground beef. This time I used a spice mix from Owen’s BBQ has a cure right in it. I normally do my own mix so I can keep the cure to a minimum. 5 hours in the dehydrator does the trick.
I do love a hood smoked cheese.
Don’t know didn’t check it.Any idea what the finished weight was? Just curious don’t go out of way to answer that.
It sounds tasty.
And he has already eaten too much of it to check now!Don’t know didn’t check it.
And he has already eaten too much of it to check now!![]()
Might have to try that.I do love a hood smoked cheese.
When I was in China I ate a lot of stuff that I had no clue what it was. There was one thing that was just amazing and it turned out to be smoked tofu.
