Coolant Disappearing, need help
Dinows
Mercruiser 8.2, engine runs great but when I check the following morning coolant jug almost empty, refill and same thing happens after running and sitting overnight. no leakes I can find anyplace. The coolant is going someplace ?? Any ideas ?
either you have a leak into the raw water side or the oil/combustion side.
drain the coolant, do a pressure test. fix the issue.
cyclops222
Weird head & intake gasket leaks will suck out out and put it into cylinders.
Check how each spark plug looks. 1 or more may show the oil burning problem locations.
Dinows
The fumy part is I can run the thing for half an hour and do not loose any coolant, but when I come back the next day coolant jug is almost empty !!
Fluid expansion when heated. When you key off, heat soak will force the coolant out somewhere
Pressure test the cooling water system (after draining)
Dinows
Ok I am loosing pressure, but how do I find out where it is going ? This is a low hour engine that has always run like a charm. Oil is perfectly clear, runs smooth as a baby's butt ?? What do you think ? Thanks
Low hours just means it sat. In a boat, 50-100 hours a year is normal usage
Now you start pressure testing components such as the heat exchanger, exhaust elbows, etc.
cyclops222
Wait 15 minutes after shut down. Check for oil around the boat. All your refills would have filled the bilge ?
04fxdwgi25
Until he does a pressure test and the stuff mentioned here, there is not a lot of use rehashing everything. Everything can't be okey dokey and coolant still vanishing unless it's something obvious like a bad radiator cap blowing off early / when pressure rises for a few minutes after shut off.
In order to find the leak, you can do another pressure test and listen for the air escaping. You may need a mechanics stethoscope in order to locate it.
cyclops222
Could a person be sucking the oil out with a little battery pump ? Just to cause you grief ? Bad joke ? We are getting close to that kind of crap.
