Cooling diagram 305 V8
Sean-Nos
Hi guy's I am doing up my V8 and wanted to do away with the circulation and use the cross over pipe at the top of the photo and just the raw water pump I also have to go through the oil cooler off the gearbox, any help photos or diagrams on how to plum this would be great. THANKS
Re: Cooling diagram 305 V8
Ayuh,... What drive are ya runnin',..??
The Alpha 1 don't really move enough water to do what ya want, 'n when the T-stat closes, there'll be Hot Spots in the block, 'n heads...
Sean-Nos
Sorry forgot to say it's a jabsco raw water pump feeding the engine, no outdrive as it a shaft from borg warner 1-1 gearbox. You can see the link to my build below in "My new build"
