Cooling Question- Quick Reply leaving in 30minutes...
merc_500
AS you know i got the Johnson ('62 40HP) running. Runs fine, but i'm not sure whether its cooling or not. <br /><br />I have it started up in a bucket with the water an inch or 2 below the cavitation plate.<br /><br />I did not see anything coming out the exhaust relief hole. But i'm not sure whether the motor is deep enough in water? <br /><br />Also, rite after i started it, i removed the thermostat and it was open, and then when i went to replace it it was closed again. I guess this varifies that the stat is working. <br /><br />by the way, steam came out when i removed the thermostat. i'm hoping its just not deep enough under water? <br /><br />someone please respond we are hoping to take this boat to our cottage in about 30min to and hour so i need to know! <br /><br />Thanks guys i really apprciate your help i love this website.
Re: Cooling Question- Quick Reply leaving in 30minutes...
Poor thing will never pump water if you submerge it in "water an inch or 2 below the cavitation plate". The water pump is about 5 inches above the cavitiation plate and in order to work needs to be primed and that means it needs to be under water. Running the pump dry is a death sentence for it as water is its lubricant.
merc_500
f***. atleast i havnt run it to long...... if i spray water up the relief hole will that hurt anything in the process of preventing anything from blocking the passageways??
What??? Spray water where?
merc_500
its ok, i think i found something else. i removed the thermostat, the thermostat "housing", and the plunger underneath had 2 plastic elastics tangled up in the spring, so i removed those and sprayed water down the passageway and saw the water come out the bottom of the motor :) <br /><br />so if anything was clogging it its not clogged now. <br /><br />but what i meant before was to spray pressurized water up the exhaust relief hole where water spits out.. in case anything was blocking the passage way but i wasnt sure if i would wreck/hurt/damage anything.
Spraying water into the exhaust system does run the risk of forcing water into the cylinders, not good
