cooling system check
IMP
What should be checked for when doing a cooling system check. All hoses look to be in good shape. ran it 16 miles yesterday and ran around 140 -/+. I have not replaced thermostat in 5 years I have had boat & assume it is original. Is this something that should be replaced periodically or not until it is broke-though it will probably go at a most untimely manner.
Re: cooling system check
The raw water Impeller Should be changed every year.. or two......
