Copper head gasket
hotrodjohn71
The head gasket for my 1951 elgin 16 (2 cylinder) needs replacing and are non existent. This head gasket has the metal ring (goes around cyllinder bore) infused to the gasket.
Since they are unobtanium, what about making a copper head gasket of the ssme thickness?
Lou C
Copper would cause galvanic corrosion between it & the alu block & head!
1000 series aluminum (commercially pure) wouldn't last long given the pressure, temp and the lack of oxygen.
C110 Copper would be a much better solution
