Copper or not?
jaybird56
i am changing from short shaft to long shaft and water tube broke do you really need copper tube or can you use alum.? will it make a difference which type is used?
Daviet
Re: Copper or not?
Are you replacing the tube, I think a new one is made of copper.
If you are trying to patch it up, how are you going to attach a copper tube to an aluminium?
jaybird56
Re: Copper or not?
will connect them with a 3/8s rubber gas line and clamps, already put it together and checked water flow is good, will test on river next week, might just be a temp fix . what yall think use copper or if works this way leave it??
boobie
Re: Copper or not?
If it was my mtr I wouldn't feel good about it. Get a new tube and install it. JMHO.
hall832
Re: Copper or not?
I agree with metriccrescentwrench & boobie, get the correct part and install. Peace of mind.
the machinist
Re: Copper or not?
If you are going to even be close to saltwater, the aluminum will disintergrate.
jaybird56
Re: Copper or not?
why is the water line copper ? most of the rest of the motor is aluminum. does anyone know?
jerryjerry05
Re: Copper or not?
Copper doesn't usually corrode.
Aluminum is cheaper and easy to mill.
Handles heat real well too.
jaybird56
Re: Copper or not?
thanks jerryjerry05 i didnt think about the heat,, it is close to the exhaust at the place i joined together but i dont think it gets very hot and has water all around it when in use. still plane on testing it in river this weekend and next water pump change i will go back to copper
jerryjerry05
Re: Copper or not?
The aluminum will last a long time.
I saw a guy fix his broken tube with just a piece of hose stuck over the tube.
Worked for over 10 years.
Saw PVC pipe in there too.
Lot's of jury riggin going on. :)
jaybird56
Re: Copper or not?
thats good to know since it has a new water water pump in it, might be a couple years before i want to take it apart again,,,Thanks
