Correct Gasket
mtnrat
Is this the correct gasket for my exhaust risers? There are only little holes at the front and back. Should I enlarge them to match the elongated rectangles?
Re: Correct Gasket
Nope......
Just Clean up the gasket mating surfaces of the Manifold,+ Riser,....
Then bolt them together....
mtnrat
Re: Correct Gasket
Thanks for the quick reply so I could continue the work. :)
