Correct Impeller part number for 15hp VWB 52119B found.
sentinel
The OEM part number used by Quicksilver is 18-8903, and (may) another cross reference as 47-F436065-2.
This is a robust impeller which measured and fitted well and appears to be a direct substitute for Chrysler's original impellar number for the VWB 52119.
e-bay dealers among other on-line parts sources show an impeller for the 15 HP Chrysler motor as useable on a "number of other motors" including the 7.5 HP Chrysler VWB 52179A. THIS IS NOT TRUE! The VWB 52179A impeller is about 1/2 the physical diameter of the Quicksilver OEM part above. Beware!!
-Larry
Re: Correct Impeller part number for 15hp VWB 52119B found.
-Larry
18-8903 is a Sierra part number, not a Quicksilver number.
sentinel
Yes. It was a Sierra label placed on the Quicksilver package covering the Quicksilver 47-F.... number.
Both sources can be used for replacement. -Larry
