Correct size socket..
Re: Correct size socket..
I think I used a 1/4" box wrench, and had to grind it a bit thinner, so it would fit. BTW - You need to replace those bolts, rather that reuse them. If you reuse those bolts, there is a real chance they will fail and cause the motor to throw a rod. Don't ask how I know..... On the older Mercs, connecing rod bolts and lock nuts may be reused....
canoemang
Ive decided to not remove them nd go the old style route of installing all 6 cylinders at the same time. I have replaced all rings and 3 cylinders already. I have a buddy coming to help me.
on a side note: Chris I greatly appreciate your input on these forums, i am sure im not alone on this. As always thank you for your help and advice!!
redjmp
You need to purchase 6 special ring compressors from mercury to do all 6 at a time .....
canoemang
No sirs.. big hose clamps and strips of pop/beer can worked just fine. ;)
There are a few methods where the special merc tool isnt needed.
You didn't drink all that beer before the repairs, did you....? Note to self, don't attend maiden voyage....
canoemang
lol.. no.. no i didnt.. during and after.
NEVER DRINK AND WRENCH.. you lose your beer and your wrench :)
So you needed to drink a beer everytime you wanted to install a piston? Well that does spread it out a bit...
