Cost of Merc water pump replacementy
Riverok
Looks like I'll need a new water pump on my 25 HP Mercury 2-cycle motor. What is a windshield estimate on the cost of this please?
Is there any chance the motor was damaged when the pump failed?
GA_Boater
Cost depends on who is doing the work. Parts will probably cost less than $100 for a full pump R & R. What is the serial number? If a shop does the work, probably triple or more. Not faulting shops - They need to eat and pay employees/overhead.
Did it hurt the motor? It depends on how long before you knew it was hot and what you did then.
flyingscott
Do a compression test first before you spend the money. If it is a mercury designed motor they do not like to be overheated.
