Counter Rotating Mercruiser Stern Drive
K Hultgre
What exactly is different in a Mercruiser outdrive that makes it counter rotate. Gears, Shift linkage, ????
jeff13601
Re: Counter Rotating Mercruiser Stern Drive
Hook the battery terminals up backwards. Just kidding, dont do that. That is a good question, Im curious to know now you brought it up. Someone will reply soon
I Don't Remember if it's the Upper Gear Set,.. <br />Or the Lower Gear Set,............<br /><br />But,....<br />I Do Know that 1 or the other is Cut in the oppsite Direction................
