coupler change
buggiedad_67
whats up all havent been on in awhile, need some info, i have a 86 glasstream with a 120 merc i/o. the coupler striped on me and i went and bought a new one it is the round type that bolts in the middle of flywheel, however when i pulled the old one it is the old type that looks like a triangle. will these interchange. i bought the boat used 5 years ago and the owner said at the time it had just been rebuilt could they have put the wrong one on?
Re: coupler change
Ayuh,.. I'd think an 86 would be the triangler 1....
The little rubber donut 1 was used in the Model 1 drivess...
I think it'll be too Short...
buggiedad_67
Re: coupler change
thanks bond o i went out and put the new one on after measuring the old one front flywheel face to end of coupler. these measure almost identical the new one is about 3/16th longer.
bigskiohio
Re: coupler change
dont forget the special spline grease and alignment.
