crack in hull - need your expertise!
Matrex
First timer and need help. I have ripped out my transom but am stopped until I know what to do to solve this problem.
Crack in hull at bottom motor mount point. Water does penetrate. Removed rotten transom, and see that the materials the hull is made of have delaminated. What do you suggest is the proper course of action to fix...
Outside:
Inside: Crack in left motor mount; delamination
Many thanks
Re: crack in hull - need your expertise!
Ayuh,....
Grind it out abit, Putty it back in+ continue Fixing the rest of it....
Once the New plywood is glassed in,.. That crack will be nothing but a Memory....
Matrex
Thanks. Will grind out the crack. What do you mean by "putty". First timer....
