cracked vinyl on seats
el toro
Does anybody know of a way to repair cracked vinyl on seats without replacing the vinyl entirely? - Thanks
Re: cracked vinyl on seats
Ayuh,......... Duct Tape.......
mike64
I got a vinyl repair kit for a tear in one of my vinyl seats. I wasn't expecting much, but I was pleasantly surprised by the result. You spread this liquid vinyl "goo", then put a pattern mold that simulates the fake leather texture, and apply heat to cure. Follow the directions carefully, and go thin when you apply the liquid vinyl! I applied it too thick at first and it took forever to heat-cure. Ended up blasting it directly with a heat gun until the seat started smoking a little.
el toro
I don't know if that stuff will work for me... the seats are split all across the top of the backrest. I could try it but might just have to resort to the duct tape lol!
TheWoodCrafter
If the vinyl it cracked from the sun forget it. It is too far gone.
jennis9
el....
i had a seat that split close to the trim - had an upholsterer take the trim off and tuck the vinyl into the seam and put the trim back on. worth a try. cost me $20
also love to use tear-aid for vinyl
Coors
Mine (1988) were split across the top 3/4" wide at places.
no hope, I just smeared in some quality Latex/poly caulk to seal the foam from water; held good for 2 years now. Ain't pretty, but new vinyl is a pain.
Rebuilding the powertrain and wiring came first. Cosmetics come later.
redfury
There's always the ugly seat covers they sell in the overtons catalogs. :eek:
