Crankcase seal questions
hotrodjohn71
On an Evinrude V6 motor, 235 horsepower, what kind of symptoms would you see in performance with failing or partially failing crankcase seals?
Model # of your machine ?----Your low speed operation / idling would suffer.----What is your motor doing / not doing ?------Post your compression values on that crossflow motor.
