Cranks but won't turn over
RyanM3
My boat cranks but won't start. I have read many forums and can't figure out the problem. The safety lanyard was broke so i took it off the ignition switch. Where should I start? It seems to be getting gas.
Mercruiser 3.0L 1987 glasstream 172
Re: Cranks but won't turn over
is the switch the lanyard was attached to in the "run" position??
RyanM3
i took the safety switch completely off.
RyanM3
i don't think it had any wires attached to it just a round thing that would look like it would flip the key to off position if the lanyard was suddenly removed.
Pete104
There are wires connected BEHIND the Kill switch. They are "purple". Push on connectors.
RyanM3
The kill switch is on the ignition switch. so is there a purple wire connected?
so this ignition switch has a kill switch built into it, yes??
i am guessing the kill switch portion is spring activated and the lanyard was attached to some sort of clip that held the kill switch portion "up", and when you removed it the switch fell "down" into the off position??
it sound like you may just need a new ignition switch, if you jumper the wires going into the switch, red/pur to purple, do the guages move??
red/pur to yel/red turn the enigne over??
RyanM3
the ignition switch still works. when i turn it to the on position, the dash lights up. When i turn it to the run position, it cranks but nothing else. how do i test for spark?
Pete104
What kind of engine is this? Got a serial number?
spark tester in between coil tower and good ground
crank engine with key and look for spark at the tester
no spark = time to troubleshoot the ignition system from the key to the coil
spark = time to troubleshoot the fuel system
