Crankshaft damper
TankerDan
I'm trying to remove the damper from the crankshaft. The damper doesn't have a retaining bolt, is it just a press on part? There isn't a large threaded hole like in every other crankshaft I've seen. My manual doesn't say anything about it. Also can I use a regular remover? It's a'98 3.0 . Thanks for any knowledge you can give me as you can see I have a lot of clean up to do on it16296636586747022950599908918893.jpg
Sunburn71
I've never see one without a bolt in it. Without the bolt, you are relying on the keyway to take the load which could cause serious issues. A puller will get it off, but be sure to clean the threads in the crank and get a bolt in there. Just my 2 cents.
Sunburn71
I just googled images of the motor. I don't see a bolt in any of the photos so don't take my word for gospel. It may just be pressed on but that's a new one to me!
TankerDan
Thanks guys, its the first I've seen without the center bolt. In fact now that I got it off I found the crank isn't even drilled for the center bolt. So I guess the marine crank is deffinatly manufactured different then the automotive crank
The 3.0 is an industrial motor, so not a regular GM block
Use a puller to remove
To install, put damper in oven at 220 degrees, place block on ground with crank flange supported on a block of wood with snout pointing up.
Drive damper on with deadblow hammer
76SeaRay
Make sure you use a three legged puller attached to those 3 bolt holes otherwise you will damage the damper. Oops, I guess you said you already got it pulled.
Don't get it much hotter then 220, so seal won't be damaged
TankerDan
The 3 jaw puller was easy, I have a bunch of pullers I need for work. Heating the damper before installation is a great idea, I don't think the manual mentioned it and I wouldn't have thought of it, thanks
tank1949
Me too!
GM inline engines for decades never had a crank bolt going back to the 20's thru the 70's
TankerDan
Hi guys, long time no post. So before I put the engine back in I wanted to make sure the transom is sealed and not leaking. I mounted the outdrive, took a hose, put the handle on jet and hosed it down around gimble housing. No leaks but I wondered if it was a good enough test. So I then thought I'd take it to a local lake, leave the transom straps on and back it into the water until the outdrive was under water. I backed it in until the water was up to the middle of the housing, checked and no leaks so far, wahoo. I backed it in further, climbed in to look and noticed the boat moved a little, so I ignored it, but still no leaks. So I looked over the stern to see how far I had to go. Strange the water was still at the same level. I then noticed the ramp was moving to the side. I looked up and found the trees were moving. It seems the trailer isn't heavy enough to get the whole housing under water. I had a good laugh about it, so now I guess I'll set the engine in and retest it. Fortunantly I have plenty of time on my hands
nola mike
I did the same thing, with the same results, during my engine install šŸ˜„
