crest liner 14 sportsman on a ez loader trailer
pelican*
Have a crestliner 14 on a ezloader trailer. will be launching with a small car, i believe a trailer extension may be needed.? Your expertise will be appreciated, thank you for reply.
Cant tell without pics, sometimes it depends on the ramps you use. I have a 12" hitch extension that I use as our ramps are fairly shallow. When you use an extension you drop your tow capacity, so keep that in mind..
pelican*
This is a picture of new to me crestliner 14 sportsman side console with casting deck. no longer has a motor, motor was a mercury 25hp. 2 stroke which are not allowed on the fishing lakes close to me. have not tried launching with my car yet need new tires and service bearings, trailer has a short tongue for launching with a car?
pelican*
pelican*
Updated photo of my crest liner sportsman
Depending on the Ramp, but I never get my feet wet on this Ramp, launching or loading. Sometimes I don't even back in this farDSC_0074a.jpg
Also get that trailer set up so the boat centers itself and glides up into position !! Having the right setup has everything to do with making the launch and retrieve go easy and keeping your feet dry !! From your pics, you need some side guides, simple, easy to install and makes a big difference !!
