Crestliner Color Codes
joeltjen10
I'm trying to find a PPG color for a 2002 Crestliner Almond Color. I believe it's the base color of my Sportfish 1850. I've taken the code to the local automotive shops and they aren't able to find anything that matches. The Crestliner Paint Codes doc only gives the below
Sierra 7881 Doe
OR
DMC 900 1105.4
DX 995 1200.6
DMC 908 1281.6
DMC 929 1315.9
DMC 923 1325
Any idea on other ways to track down the PPG color that doesn't involve a color match tool at the auto place?
Thanks in Advance
AShipShow
did you try calling crestliner? They may be able to help point you in the right direction... I assume the only suggestions you're gonna get from someone here is to just get a color match.
Also, is it gelcoat or paint? Cuz 17 year old gelcoat is not gonna look like it did from the factory. You might actually be better off getting a color match than ordering the factory specific color.
Ayuh,.... I just try to find a color that compliments the parts of the boat, I ain't paintin',........
Matchin' old paint or gelcoat is 'bout Impossible,.....
