crusader exhaust log to center questions
crzychrs
i have twin 1987 crusader 270s out of a 87 cruisers elegante 297. both motors have been rebuilt and out of the boat. the old log style mannifolds are shot and i got a great deal on center rise mannifolds. my engines are fwc. as far as i know to use these i need to change my thermostat housing, part#?, and alternator bracket, part#?. also if anyone knows how the plumbing is routed for fwc.THANK YOU to all who reply.:):) i will try to attach some pics.11-6-12 phone 129.jpg11-6-12 phone 133.jpg11-6-12 phone 138.jpg11-6-12 phone 136.jpg
Re: crusader exhaust log to center questions
i have twin 1987 crusader 270s out of a 87 cruisers elegante 297. both motors have been rebuilt and out of the boat. the old log style mannifolds are shot and i got a great deal on center rise mannifolds. my engines are fwc. as far as i know to use these i need to change my thermostat housing, part#?, and alternator bracket, part#?. also if anyone knows how the plumbing is routed for fwc.THANK YOU to all who reply.:):) i will try to attach some pics.View attachment 178052View attachment 178053View attachment 178054View attachment 178055
Ayuh,.... Those manifolds don't even match,.....
Hard to believe you rebuilt the motor, yet yer puttin' used, mismatched manifolds on 'em...
I don't see many Crusaders, so I'm guessin' the 270s are SBCs,..??
crzychrs
yep sbc 350 cid. and yes they are used but in great condition and both fit 350 sbc. the black are off a merc 350, a buddy upgraded to ss. they were a gift. the center rise conversion kit for my engines show the exact same manni's. @$1600. the others are also show as compatible in plu search. risers are shot mannifolds are salvagable. kinda tapped out after two motor rebuils, one tranny rebuild, starers, alt, water pumps, ect. So if i am able to use these and convert to a better system{log vs. center} with what i have less the small stuff, then i feel like i need to at least research and give it some consideration. thanks
Lyle29464
I have never had any luck getting the plugs out of used manifolds to set up closed cooling. Also this setup will be several inches taller.
