Cutting FG
Oilguy
Here is a trick that I have found...
I bought a 7" grinder when I burned up the 4" and I found that a 7" dry concrete/tile blade work VERY well on fiberglass... It cuts clean and doesn't throw a bunch of dust >> Doesn't kick back >> And cuts like butter!
OG
Re: Cutting FG
So when you smoothly slice right through the hull.... you will not even feel it :eek:
Just some advice just because it is less dusty do not stop wearing a mask.
