Cylinder head swap 115 V4
Your stock jetting should be pretty close, if not already perfect. It has the tuned exhaust so that's not going to matter. The only thing changing will be the compression ratio. That usually doesn't affect mixture much.
bob johnson
you had mentioned you were thinking of going to a mid 90s looper head... and for sure that wont fit onto a crossflow motor...
No----He mentioned going to a 140 looper powerhead.--------he was imformed that it would not fit the adapter plate.
TurboJet
No Title
Thanks Spicers!
TurboJet
No Title
$125 each
Looks like I got some work to do if I want to get back on the water!
Also gives me a reason to take a look at the pistons
Attached -
This adapter plate is a strange contraption!
Installed some new gauges and painted the dash (head temp -- water pressure -- head temp)
Pulling the powerhead
