dangling plastic tape
daniel2229
After loading the boat and pulling it from the water my wife said there was something dangling from under the trailer. Unfortunately, I couldn't get under the boat to investigate because there were others pulling out behind me waiting to de-rig their boats. So, I reached under the boat and pulled off what appears to be a two foot by four inch piece of white tape.
Could this be the white plastic wrap you see shrunk around boats going down the highway on the big boat transporters? Why would this piece still be attached to the bottom of my boat? I have had it in the water maybe 15-16 times.
The tape material was caught between the boat and the bunk.
Thanks,
WillyBWright
Re: dangling plastic tape
It's the Keystone Tape that most manufacturers use to keep the hull from splitting in two. You know what a Keystone is, the one stone that if removed makes the whole structure crumble to the ground. ;)
Might've just been something floating around in the water that got caught between the trailer and boat when you loaded.
Oh No,............ Not the KeyStone Tape issue again,........:D
daniel2229
You know that keystone tape maybe something I need to look for at Overton's. Do you think it is expensive?
I noticed my boat did take up a lane and a half of highway on the way home, and I could barely get it into the garage! Thought it was because I was so tired.
The best keystone tape is carbon fiber laced..... a bit hard to find.
Coors
Yeah, I read that, but it only works with epoxy. It reacts against Styrene.
Naw,.........
I use the Stuff I get from the Hardware Store,.......
It comes on a roll,... It's grey or maybe silver,......
And,......
It's Stickier than 'ell..............................................................;)
