- Joined
- Jul 23, 2011
- Messages
- 52,521
I would also suggest not changing the layout of the power. one good running motor in front of a well maintained outdrive will last a long time. converting to twin I/O's will be expensive, not to mention, you probably do not have the room.
being an IO, your limited on power only by your checkbook. there are single I/O ,motors available with over 1600 hp (however that would be overkill). however in your case, a good 300hp small block in front of the Alpha drive will be plenty.
