Deck drains!
prockvoan
Guys,I been looking high and low for some replacement hatch channel drains.The drains I am looking for are a 1" tube with treads by 2" long,top part is 1 1/4" flat flange top,just like a sink drain.<br />Anybody know were I can find some?
flashback
Re: Deck drains!
try page 545 of the new boat US catalog.. made by forespar..called flush head marelon thru-hull fitting... ;)
prockvoan
Re: Deck drains!
Originally posted by flashback:<br /> try page 545 of the new boat US catalog.. made by forespar..called flush head marelon thru-hull fitting... ;)
Check them out,flange top is to big,its got to be no biger then 1 1/4" OD.Thanks anyway!
flashback
Re: Deck drains!
You could probably grind the flange down to the size you need... :D .. anyway, if i see something else, I'll give you a holler........
